Revshift trans mount insert w UMI motor mounts & UUC shifter
Just inserted the Revshift trans mount insert. For the record, there is no interference whatsoever-- works perfectly with the UUC shifter and UMI motor mounts.
Shifts are now smooth and no more high RPM lockout from 5th gear. Unexpected benefit-- the car would lurch a little when letting off the gas while cruising and in gear. That is now history.
Probably the single most cost-effective, satisfying mod I've done to the car.
Yes, there is a little more howl that travels into the at at mid throttle to WOT, but then I am rocking solid mounts and 10 degrees of overlap on my cam. For me, it's a plus. Others may feel differently
