Build or buy?
Old 07-14-2013, 06:34 PM
zmandan's Avatar
Default Build or buy?
New to the LSX platform. Wanted a high H.P. LS for drag racing. 700-800 horsepower at the rear wheels is my goal. Since I haven't worked on LS motors before I'm a bit leary about trying to build one. Wondering if there is a place that builds them with that much H.P. that can be dropped in. Only condition is no power adders (for now). Or should I just jump in and start getting my hands greasy? Any thoughts?
Old 07-14-2013, 07:35 PM
Knight-Z06's Avatar
maybe try an erl superdeck block and a set of ported ls7 heads , a single plane intake as well
Old 07-14-2013, 07:49 PM
lil john's Avatar
Call Vengeance,HKE,or LME... 800hp is just a call away, thank you for dialing LS1tech... oh yeah be sure to bring your Checkbook or any major Credit card with over 9grand minimum.Again thanks from LS1tech.
Old 07-14-2013, 08:04 PM
Knight-Z06's Avatar
haha i wish i had money to spend like that
Old 07-14-2013, 08:13 PM
lil john's Avatar
Block$2000 min-Rotating assembly$2000 min-Heads$2500 min-Induction$1300 min-Electronics$1000 min-And the over all engine build it self boring,honing...etc 2500 min not including Solid roller cam and Jesel rocker arms also lifters....500,1500,600 all are min prices.....
Old 07-14-2013, 09:01 PM
Knight-Z06's Avatar
haha i had to buy my block on layaway (thansk thompson motorsports)
Old 07-16-2013, 08:35 AM
zmandan's Avatar
I'm getting prices for 20k+ for a complete 800 H.P. engine ......is that the going rate? I was hoping for 15-ish.
Old 07-16-2013, 08:40 AM
lil john's Avatar
call this # 713 849-4505 ask for bryan (IT"S) LME racing engines let me know how it goes. I'm going to meet brother for a Smoke session and brunch! Let me know what part of the world you are in and I could probably get someone closer... but I would stick to LME he's done this well over 1000 times tell him Paco the 1 eyed black dude with the Explorer sent you.He'll give you the best bang for the buck.....
Old 07-16-2013, 10:24 AM
Sawzall and Welder Mod
Whistler's Avatar
800HP and 800 RWHP is a huge difference. You can make 800 crank HP with off the shelf parts. 800 RWHP is going to take much more carefully selected, and expensive components and expect to pay accordingly.
Old 07-16-2013, 04:30 PM
SweetS10V8's Avatar
RHS race block.... 500ci in the same size shortblock as a regular 5.7l
Old 07-16-2013, 04:45 PM
214Chevelle's Avatar
Bryan @ LME is gonna build my RHS 427 LS7 built for boost with MAST's large bore LS3 heads. Quoted estimate.....$14k. So, if you're estimating $15k, you're right on par for something built to handle 800 hp. Don't forget headers, coils, wires, tuning, harness, etc. That's extra.
Old 07-16-2013, 05:11 PM
Originally Posted by bozzhawg
Shiiiiiiiiiiiiiiiiiit
Yeah, that's what I said bro. By the time I add the price of the Kenne Bell 3.6, which I already have, I'll have over $20k in this engine and it's just a street car, no racing.
Old 07-16-2013, 06:01 PM
zmandan's Avatar
I got 2 letters for you "FI" will be the easiest way.
If NA, I would be thinking cubic inch= LSX 434ci 440ci or 454ci. There is no replacement for displacement.
But how fast are you trying to go? 700-800rwhp, you better have a chassis, suspension, and drivetrain that can be able to handle that power, because if she ever hooks, say goodbye to your chassis, drivetrain, and suspension.
car is set up to race. it can handle it.
the price I got was from LME. definitely has a good rep from what I see. quote I got was $27,000 complete including engine mgmt. bout 7k more than I figured. Guess going LSX is more expensive than I thought.
Old 07-17-2013, 10:40 AM
CAMSTER's Avatar
I say get your hands dirty and don't let yourself be pinned to bondage of depending on any one if you can do it yourself.
I decided a while back to go back to racing after I raised my childrens, that's when paid every penny asked to Brian at LME sent me a complete engine but did not start, every thing was rite drove me nuts, I decided to take the car to the dealer and let the techs go true it, they kept the car two days, asked me to take the car away everything was rite according to them should start, took it home till one day I decided to look in the crank sensor hole on the original block and compare to what was in the new one, that's when I discover the problem, I didn't even know at the time what it was, it was all new to me never used nothing but distributor before, it was the wrong relucter wheel, lesson number one, never ever buy an engine across state line, cause when you have trouble as Brian said is your fault and never took responsibility or helped in any way to remedy my situation, back then there was no conversion box so I had to take the engine out and disassemble it myself and send the crank back to manufacturer to change the reluctor wheel, in the process I found the double roller timing chain was rubbing the oil pump and though did not start there was a lot of metal shaved off in the area.
Lesson learned do it your self no body will beat you, no body will burn you, and the satisfaction will be, always all yours and what you learn will be priceless.
Plus you can get much better parts with the money you save.
Just buy a book on how to hot rod the LS engine.IMO
Old 07-17-2013, 01:12 PM
lil john's Avatar
Mr.Dos Equis,,,,,,,,,,One thing I do KNOW for FACT if You can't put it down to the pavement= KNOW USE oF HP........IF Drag GREAT
For the street... Got 4 wd cause Porsche VS 20...........Corvette,Ain't going to Cut it.
Old 07-17-2013, 02:27 PM
CAMSTER's Avatar
LSX cast iron block shipped around $2,500
crank rods and pistons 2,900
Mast Heads TD machine rockers/push rods 4,700
cam lifters timing chain 1,850
engine block covers/valve covers block plug kit oil pump oil pan $900.
intake and throttle body 900 to 1,700 depending on whether hood scoop or closed hood and cable or drive by wire
harmonic damper 400.
So far about $15K all first class parts then add an M40 GM computer 200. plus 800 for harness 400 for fuel injectors
Then add 900. for machine chop $17,300
I say 700 rear wheel no problem you may have to go to a front mount distributor to go 800 rear wheel due to rpm range.
A 440 Ci solid lifter 14 to 1 compression with a 6 bolts per cylinder block/heads arrangement Mast 305 heads you are there.
With a carb style throttle body / intake combo from Mast will be too easy.
Old 07-17-2013, 04:27 PM
lil john's Avatar
What tire LOVE engine One thing I do KNOW for FACT if You can't put it down to the pavement= KNOW USE oF HP........IF Drag GREAT
Old 07-17-2013, 04:36 PM
lil john's Avatar
One thing I do KNOW for FACT if You can't put it down to the pavement= KNOW USE oF HP........IF U Drag GREAT..I'm street...... HELL DO me 10 sec street club I<<<<<<<<<<<<<<<<<<<m there.
Old 07-18-2013, 08:45 AM
zmandan's Avatar
I like the way you think!
Quick Reply: Build or buy?
