95 camaro 3.4L V6 removal..
Guys just wondering if anyone has a step by step on how to remove the 3.4L V6 engines in the 93-97 Camaro. I know how to remove & replace an LS1 in a camaro(I have a book for it lol). Havent messed with an automatic transmission so I dont know what to unbolt,disconnect,etc.. planned on pulling engine & trans out the bottom together same way I did the LS1 in my other Camaro.
Can't be too different than removing the 3.8 which I've don about 5 times in the last year. It's the same concept as the LS, just a different engine and trans.
I can probably answer some of your questions.
It's pretty straight forward. If you've pulled an LS you should be fine.
You might probe some of the guys over at fullthrottlev6 or at v6f-body
