Deleted HVAC Waterpump Connections
Old 07-16-2013, 06:18 PM
MEAN LT1's Avatar
Default Deleted HVAC Waterpump Connections
Just as the title says. I removed the hvac in the car and dont want to just cap off the water pump. What I would like to do is cut off the hose ends off the water pump and plug them with some kind of AN fitting of some sort?. Anybody have any pics of what they did when they got rid of there hvac hose connection on thee pump?
Old 07-16-2013, 08:06 PM
shbox's Avatar
You can pull out the pipe stubs, then tap and plug the holes. That would be pretty clean.
Old 07-16-2013, 10:09 PM
Jason94z's Avatar
I cut "B" just long enough to jam on "C" after I took "C" off the pump in this thread I started here:
https://ls1tech.com/forums/lt1-lt4-m...lines-pic.html
Old 07-17-2013, 10:42 AM
sweetbmxrider's Avatar
Pull them out and put in freeze out plugs or thread and plug like shbox said.
Quick Reply: Deleted HVAC Waterpump Connections
