New Moser ford 9 in car... strange lock up issue?
Old 07-18-2013, 07:35 PM
Droptoplt1ta's Avatar
Question New Moser ford 9 in car... strange lock up issue?
I just installed a Moser Ford 9 in my 98 Camaro. I broke it in on jack-stands, drove it around block, and then drove it around town X2. It drove great. I tried to take it out again, and it locks up going forward.... I can idle creep and go around the block all day long. I can go in reverse all day long.... In forward gear give it some gas it will lock, then unlock and repeat.
I have removed the parking brake shoes and unpluged the ABS sensor and no change.
I dont know WTF is going on here, I need help
Thanks
Old 07-18-2013, 09:42 PM
I think it may be in the trans? I installed the Moser ford 9 because I blew up the 10 bolt... its possible that when I blew the 10 bolt, I did some damage to the trans??? The first few times I drove it though it seemed fine?
The 4l60e output shaft seems to have about 1/4 play in each direction... over 1/4 inch play up and down...
Quick Reply: New Moser ford 9 in car... strange lock up issue?
