What makes these sound so bad ass?
Old 07-18-2013, 09:40 PM
oscs's Avatar
Default What makes these sound so bad ***?
I realize the cam has alot to do with it but I'm about to redo the exhuast on my lq4 swapped 77' 280z and I'm after the crackle that I hear alot of vettes spitting out. What is it about the vettes that make them sound so badass? I'm building a dual 3" system with an x pipe and magnaflow race series mufflers. I currently have a .590 .590 114lsa cam so nothing crazy.
Old 07-18-2013, 09:43 PM
427zm's Avatar
Big cubes, big overlap, and Corsa. Corsa amplifies the crackle you hear.
Old 07-18-2013, 10:02 PM
SNlq4's Avatar
damn that sounds sick
Old 07-19-2013, 06:00 PM
Doug G's Avatar
Sounds sweet....but that driveway doesn't have one mark on it.....hhhhmmmmm....would have to fix that first
Old 07-19-2013, 06:34 PM
LS1TA_956's Avatar
I like this idle better
Old 07-20-2013, 06:29 PM
oscs's Avatar
any hope in getting an lq4 to sound like these monsters?
Old 07-20-2013, 07:40 PM
aknovaman's Avatar
Concrete floor garage and a cam, IMO.
LQ9 EPS cam specs 600-ish lift and 233-ish duration that went into my buddies 78 Caprice (Christine).
Old 07-21-2013, 11:00 AM
oscs's Avatar
Thats a cool video
Old 07-21-2013, 11:01 AM
oscs's Avatar
does anyone know what model corsa mufflers are best?
Old 07-21-2013, 11:11 AM
Grr
Grr's Avatar
a big cam and tons of compression is the main reason, the rest of it is a x pipe and basically equal length pipe with minimal bends. bends kill sound quite a bit. If you build a nice system with an x pipe you can get good sound in the Z
here is what my setup looks/sounds like so far, it should be perfect when I get the rest put on there this is all that is on it in the video
Old 07-21-2013, 11:16 AM
oscs's Avatar
This trans am sounds pretty badass too, gives me hope
Old 07-21-2013, 11:17 AM
oscs's Avatar
Ls3 fb rx7 front half exhaust with x pipe - YouTube
yeah man that thing sounds amazing! what mufflers are you going to go with?
Old 07-21-2013, 11:39 AM
Grr
Grr's Avatar
well the bumps on the piece above are these 9" dynomax bullets
http://www.summitracing.com/parts/wlk-24250/overview/
will be doing a set of full size 16" bullets in the back to quiet it down some
Have used a setup like this before and it works perfect, the small bullets that far forward do more than you would think
the x pipe is an ebay piece and its great quality for cheap, overall this is a cheap setup all the tubing and vbands are from acestainless.com whom I also recommend. the entire exhaust system is stainless from heads to tips. I think I have about $800 in it including headers, mufflers, all tubing, x pipe, etc.
Old 07-21-2013, 12:01 PM
oscs's Avatar
you running long tubes? having long tubes in an LS s30 is a nightmare and very expensive.. like $870 expensive. I cant justify $900 over shorties but i bet it makes a big difference in sound.
Old 07-21-2013, 12:07 PM
oscs's Avatar
I like the idea of using the bullet mufflers, They are louder and sound nice. I bought a set of magnaflow race series mufflers and they are huge and sound like a truck..
Old 07-21-2013, 12:08 PM
Grr
Grr's Avatar
yeah I made a set of 2" longtubes
I had been planning a 280z for the last 2 years so I know what you are talking about, but I just couldn't find on that wasn't rusted to **** for a decent price around here. Plus the FB was cheap as **** couldn't pass it up
Old 07-21-2013, 12:23 PM
Grr
Grr's Avatar
biggest thing with bullets people never get is you need as much pipe after them as you can get. If you run them on the end of a pipe they don't do very much. That is why even the small ones way up front like that work well.
When I add the longer ones in the back I will have at least 6" after them if I can fit it
Old 07-21-2013, 12:26 PM
oscs's Avatar
yup.. lookin good man. Finding an s30 that isnt covered in cancer is a challenge. I really wish i could get my hands on a set of long tubes. After seeing your pics i might try to sell my shorties and bite the bullet. 10-15hp difference is what i hear and i bet they make a big difference in sound.
Old 07-21-2013, 12:52 PM
oscs's Avatar
only thing with the s30 platform is the lack of room. If i mimicked your setup i would have to run the 16" bullets and the very most rear part of the exhaust system.
Old 07-21-2013, 01:16 PM
chuckd71's Avatar
That does sound good. I wish I could find someone with one of those test stands around here, that would come in handy.
Quick Reply: What makes these sound so bad ass?
