Fuel pump replacment question
Old 07-19-2013, 12:47 AM
ChaoticC3rberus's Avatar
Default Fuel pump replacment question
I recently bought a 99 z28 Camaro that has been upgraded to a ss. it has sit in a garage for 4 years and the fuel pump doesn't work now. I ordered a new racetronix one . but I was wondering if I need to replace the entire module as well? and where I could find just the housing. and the fuel gauge is stuck too I believe.. and advice would be greatly appreciated
Old 07-19-2013, 03:59 AM
Ollie8974's Avatar
No, you do not have to replace the module. The fuel level sender can be replaced.
Remove float arm and the white lock tab, pinch the barbs on top of the fuel level sender together, the sender will slide out.
Attached Thumbnails Fuel pump replacment question-img_1115croped.jpg   Fuel pump replacment question-img_1118croped.jpg
Old 07-20-2013, 09:42 PM
so it would be ok I just replaced the pump and float?
Old 07-21-2013, 05:40 AM
Ollie8974's Avatar
Yes, replace the pump and the fuel level sender.
Quick Reply: Fuel pump replacment question
