Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Timing pills ???
Old 07-19-2013, 01:40 PM
jaywill's Avatar
Default Timing pills ???
Which one should I use for start up ???
Old 07-19-2013, 05:44 PM
wildcamaro's Avatar
1-3 are all pretty much the same it doesn't matter...
Old 07-19-2013, 05:45 PM
89gmcs15's Avatar
What ignition? If msd I'd skip the pills and build a curve.
Old 07-19-2013, 05:50 PM
Doug G's Avatar
Make your own curve....pills have problems.
EVEN IF the map is NOT hooked up....they will add timing and one has found out and warned.
MOST say the curves are too much ?
Lots of reading at the to of this this page
Old 07-19-2013, 06:04 PM
wildcamaro's Avatar
I haven't had a problem with pills...although they might be the cause for my engine breaking up around 5500rpm...just been too busy to custom surge lately
Old 07-19-2013, 06:27 PM
jaywill's Avatar
Ok thanks
Old 07-19-2013, 10:01 PM
89gmcs15's Avatar
wild, the msd pills use a 5500 rpm limiter. only way to get rid of that is make your own curve.. and the timing seems high if ya ask me, plus the worry of the map thing adding timing
Old 07-22-2013, 10:39 PM
ignatz's Avatar
The rev limit is just a number in the computer independent of everything else and easy to change
Old 07-23-2013, 07:14 PM
wildcamaro's Avatar
Yea I changed rev limit even while using pills
Quick Reply: Timing pills ???
