trans slips and the trans is fine, help
Old 07-20-2013, 03:10 PM
quigman's Avatar
Default trans slips and the trans is fine, help
Hey guys I have an 05 lq4 and am having trans problems that I believe are electrically oriented. First I will say the trans has 40,000 miles on it. It has been removed and tore down to reveal absolutely nothing wrong with it. The problem is when you drive with moderate throttle it works fine, but when you put your foot down the motor just revs and the truck goes no where. We put scanner on it that operated the trans manually with the scanner it seemed to work much better.
The trans worked when I first got the project running. I have put maybe 50 miles on the truck since built. Please help. There are no trouble codes present.
Old 07-21-2013, 10:35 AM
Bowtie316's Avatar
What trans, what mods to motor, what tune changes???
Old 07-21-2013, 01:52 PM
quigman's Avatar
Tran is the original 4l80E from the 6.0 lq4 from an 05 2500. The harness and computer are from Howell Engine development. The tune is a very basic high-po tune with no emmisions. The engine and trans are bone stock aside from headers and cold air intake. Sorry I don't know the specifics.
Old 07-21-2013, 05:55 PM
Bowtie316's Avatar
Beats me, I would start by checking the line pressure.
Any chance a tire is spinning?
Old 07-21-2013, 07:53 PM
quigman's Avatar
The line pressures check out fine. We did update the hydraulics when we had it out to check things. We hooked up a scanner that can manually work the trans by adjusting pressures and shift points etc. The truck ran better. It seems the problem lies in the electronics. I checked all the grounds and they were fine. Amy ideas.
Old 07-21-2013, 08:06 PM
sreve's Avatar
Unplug the MAF it can affect line pressure if it is not
calibrated right, dirty or slimed with K&N oil
Old 07-21-2013, 08:44 PM
quigman's Avatar
Thanks I will give it a try.
Old 07-22-2013, 11:28 PM
quigman's Avatar
The map sensor did not work. The problem now presents differently so I will move it to another section. Thanks for the input
Quick Reply: trans slips and the trans is fine, help
