Replacing stock speakers on an '01 Z28 Camaro
Hey guys, I'm not too experienced in the way speakers work and I was wondering what the cheapest way to replace 2 of my stock speakers in my Z28 is.
Basically, one of the speakers in the front blew so I want to replace both front speakers. But I don't know squat about ohms and resistance and voltage...I looked at the help articles and they're too confusing
I have a pair of brand new Pioneer speakers from a friend who bought them for her base firebird, and got them to work great on that car, but she's giving the speakers to me 'cause she's selling the firebird.
So basically my question is, can these speakers work on my Z28 if they fit on her firebird? are they a good choice or is there a better option to fixing my sound? Thank you all for you time,
Cheers.
Cheers.
Assuming you have a stock monsoon system. The front two door speakers are 6.5"Shallow mount 2-ohm midranges with .75" 4-ohm tweeters mounted coaxially. Read the MONSOON FAQ STICKY, everything you need to know is in the sticky. Honestly if you wan't to have an easier install without having to cut/splice/solder and heat shrink your factory wires with limited space, sell the pioneers and get with Ian at KEE AUDIO a sponsor here and he will set you straight with some speakers that are plug and play. Also get rid of your stock head unit if you haven't already it's a distortion producing monster and will only strain your new speaker's and possibly blow them again at high volume levels.
My suggestion, work with Kee. I have bought one of his packages a little while back and definitely worth it. Keeps the stock setup with perfect replacements for the speakers. He's very good and great to work with.
http://www.keeaudio.com/fbodyspeakers.html
Ungrounded Moderator
It's not that Kee's replacement speakers are necessarily better than other speakers but they are better suited to the Monsoon system configuration. Otherwise, it can be difficult to find 6.5" coaxially mounted component speakers for the doors (as opposed to the non-component coaxials you'll find most everywhere) and 2-ohm 6.5" subs for Camaro sail panels. It's even tougher to find 6.5" 4-ohm dual voice coil subs for Firebird sail panels.
I did have an aftermarket HU at one time.... It did sound better than the stock HU (volume), but I hate that generic adapter look.
Since you have all that, I suggest putting it in and trying it for awhile. You may find that you like it and nothing else is necessary. You may find you want more bass in which case you can add a sub in a stealth box. Or you may find that you want more power overall in which case you can change the amplification to something aftermarket. But the point is you haven't lost anything (except maybe some time) because everything will still work as you add more upgrades - and you might end up saving yourself some time and money if you find that big upgrades aren't necessary.
