Stock LT1 & LS1 Parts + Some aftermarket
Category: Accessories
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): NY
Item Condition: Brand New
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
-Ram Aluminum Flywheel part#798-2554 This flywheel was only bolted to the crank and removed. It was sent back out to Ram because the face wasnt true. Ram says they fixed it at my expense. $350
-Stock LT1 DS $50
-Stock LT1 injectors. $40
-Stock LT1 KM $30
-Melling M55HV Oil Pump. With pickup that was tack welded in position $30
-Yellow powder coated LT1 intake (Bare) $80
-2 Stock LT1 crank shafts. Both are rough, They need to be cut down. One looks to of been polished but they both need to cut on the 1&2 journal. $120 each
-LT1 corvette Crank hub and Balancer $60
-Stock LT1 Lifters $50
-2 OBD1 timing chain covers $50 each
-Stock LT1 main crank bolts and windage tray $50
-Stock LT1 connecting rods and pistons. Connecting rods need to be refurbished $120
-Stock LT1 4 bolt mains (center 3) $60
-Stock LT1 timing chain (no crank sprocket $30
-Stock LT1 oil pump drive gear (no play good shape) $35
-Powermaster 9502 Lt1 mini starter. Was working good but would not engage the solenoid from time to time. Might of been possible lose connection $120
-Stock LT1 AC Compressor (unsure of condition) $40
-Stock LT1 Crank balancer $20
-Drivers side door weatherstripping for T-top car $20
-Stock LT1 ECU Tray $15
-New and Used Upper Radiator hose New $20 used $10
-12" O2 extension $15
-1 GM ICM and 1 Standard ICM $60 $40 respectively
-2 LT1 ECU's Both have mail order tunes on them for M6 cars $100 each.
-T-top trunk holders $40
-T-tops weather stripping (used, decent shape) SOLD
LS1 parts are from a LSx swap that is no more. Parts have roughly 100k on them.
-Used Ls1 starter. Was told it worked when received. SOLD
-Stock LS1 intake with fuel rail and injectors. SOLD
-Stock LS1 pushrods $30
-Stock LS1 Lifters $40
-Stock LS1 K-Member $100 Pickup only unless buyer would like to setup shipping.
-Stock LS1 Heads 853 cast. Come with valves and beehive springs (unsure if springs are stock) $250
-Stock LS! Aluminum DS $100
-Russel brand LS1 Center rear brake line. New never used. $20
-1 set of Salad shooters with tires. Tires are only good for rollers or burnouts. Local pickup only on these unless someone wants them without tires. Possible shipping can be arranged. $250 picked up
-Ford 8.8 3.08 Gears, Good shape $60
Also check out my thread on my tan interior thats for sale Here I Really need this stuff gone. Make me offers!
More pics available upon request.
EDIT: Im sorry guys but I forgot to mention that I will not do business with anyone with 0, or Negative iTrader rating or 0 posts . Ive had afew bad issues with people in the past. Sorry
