Glide with LS - Use Manual Wiring and PCM?
Old 07-23-2013, 11:57 AM
BanditDave's Avatar
Default Glide with LS - Use Manual Wiring and PCM?
Hey guys,
I have an embarrassingly stupid question. I beleive I am right but wanted to confirm. When using an LS engine with a non electronic trans (glide in this case) I assume I use a manual wiring harness to complete the swap. Where I get a little fuzzy is what else needs to be done with regards to VSS and any PCM mods.
Any help is appreciated and if there are some threads I could be direct to to read about it that would be appreciated as well. I seem to be coming up empty when searching and since I have a little one on the way my time is limited with doctors appointments and working and taking care of my wife.
Thanks in advance to anyone who could help.
Dave
Old 07-23-2013, 03:08 PM
ijimmy's Avatar
yes you will be fine useing you stock start request wire that went to your old starter , usealy purple on chevys
Quick Reply: Glide with LS - Use Manual Wiring and PCM?
