Fuel pump info
Fuel pump info
Soon to be bolting on a Procharger. I know that I have to upgrade the fuel system. Thinking some 42lb injectors but what pump to use? What pump do you use for your blower set up?
just passing on a little info. don't know how much hp you plan on making. but u need to ck out your fuel system close. have a c5 vette. with f1-c procharger. have 60 lbs. having some fuel problems. having to go to 95 lb inj. car making around 800 hp at flywheel. so choose your fuel system with a lot of research
