Ls1 body/chassis harness
This may be the wrong section to post but figured I would have the best luck here.
Is there anyone out there that sells custom ls1 chassis/body harness?
I only found the one that comes in the painless intergrated harness pn 60608. It has some stuff I would like to away with as well of the engine harness. I haven't called painless yet to see if they will do a custom made one yet. Just checking to see if y'all knew of anything. On a side note I'm not the best at wiring as I still consider myself a newb.
Thank you for any help you can lend me. Mod if need be, move to correct section
