4 speed pedal assembly
When going from Auto to manual what is needed besides just the brake/clutch pedal assembly?? Are there any special brackets or bolts needed or do they bolt right up where the factory brake pedal was???? It's a t56 to ls and I already have all the hydraulic parts needed including the American power train adjustable clutch master assembly. Thanks
You can use the stock assembly. you just need to mount the clutch master and mod the rods together. Use the template in the FAQ to make the plate or just buy one. But if your master lines up with the pedal and firewall, you will not need any adapter plates. Not sure what it looks like.
I just bought a repo pedal off of eBay for my Chevelle.
BC
BC
