Any one running the ATI 25%
Just wanted to see if anyone was running the 25% pulley from ATI. I've got my car torn apart for a cam , spring& pushrod upgrade and want to replace my ASP with an ATI. The ASP has been great never thrown a belt just want to upgrade for when I start hitting it with spray. I'm also interested in running it in standing mile events I know the ATI will shine at the sustained higher rpms.
I' ve also got the trickflow bracket to run an ls2 timing chain damper. Goal is around 500 rwhp and 625 on spray. Also was looking at the ATI 10% damper with the steel hub and aluminum shell.
Thanks
Thanks
No issue(s) after installing my ATI. Make sure you get the bolt with it. Mine was short shipped. I did install new tensioner and billet pullies. No problem with the belt.
