best hvlp gun for under $200
Old 07-26-2013, 08:51 PM
High torque's Avatar
Default best hvlp gun for under $200
looking to purchase a hvlp spray gun but on a tight budget any suggestions ?
Old 07-26-2013, 10:34 PM
EDS01SS's Avatar
check ebay...i picked up a satajet 2000 for 150 in perfect working order a few months ago
Old 07-27-2013, 09:48 PM
ctjohns's Avatar
devilbiss finishline works surprisingly well
Old 07-27-2013, 10:28 PM
JOHNNY59's Avatar
2nd for the finishline
Old 07-28-2013, 05:53 PM
NnOoSsSs's Avatar
sata's are a good choice but i think i prefer devilbiss alot more although i have never bought a gun that low i think i would go for a cheap devilbiss
Old 07-28-2013, 10:50 PM
ajwoodtransport's Avatar
I bought a Vapor HVLP spray gun set that included three different guns at the paint store for $115. Have nothing to compare it to other then my old bottom feed gun. Setting up the spray pattern and fluid control seemed good. I did have problems with the metallic clumping up and clogging the gun...although that's probably from user error since it was the first time, I've sprayed metallic. I don't know if it's a good gun, but the paint store has been around for years serving the local body shops so I'm assuming they are decent guns. If it's like most things....a good operator can make a so-so product work great but a bad operator can make a great product work bad. Good luck.
Old 07-31-2013, 03:45 PM
tonypaul's Avatar
Most dont believe it but the $40-$50 hvlp at Harbor Freight is great! Do a little research on them, you might be suprised. I have painted 3 cars with one and it lays out the paint just as good as any other gun I have used.
Just make sure you get the one with brass/gold colored adjustment *****..
Quick Reply: best hvlp gun for under $200
