Motor Mount Bolts - Part Number?
Just checking to see if anyone knows where to get spare motor mount bolts. As you may recall, one of mine got stripped. I plan on drilling it out, and I'll need a replacement when I do. I've already checked the various GM parts websites to no avail. If nobody has any ideas, I'll call Luke @ Lindsay this week.
Thanks!
Thanks!
Thanks!
Thanks!
You mean, YOU stripped one
Correct.
Easier said than done, since this is my only car. I suppose I could drive with one bolt missing, but that means I'd have to remove the headers twice. Also, the bolts are probably Grade 10.9, which is significantly better quality than something you'll find at Home Depot.
Hopefully not. I've got a bit extractor kit, and I've got a 1/2" drive breaker bar with three extra feet of pipe.
Dealer replaced my mounts under CPO when one blew and the other wasn't far behind. Fast forward... during my header install and putting in RevShift MMs, I found one of the bolts was missing.
Drivers side without the post on the head for the wire clip:
8900 11516328 CP36FNUT $1.65
That doesn't seem right, although I appreciate the input. According to Gabbiani's motor mount thread, the bolts are 15mm, not 10mm.
