Change pinion bearing during gear install?
I scored a set of GM 4.10's for my 32K mile WS6. I'm looking at the install kits and think I'm just going to go with the basic. I dont want to change all of the alxe bearings etc. The pinion bearing is my only question - should I change that one? Most of the basic kits dont come with one (like the one below) so I'm not sure if I should pop for on or not. My initial thought was that it is probably better to change it, but then again I don't want to change things just for the sake of changing them. If it has low miles, does it really matter? Is the bearing going to get beat up during the install?
http://www.summitracing.com/parts/mgr-gm7-5ik/overview/
Hmm. So maybe I buy the basic kit and then buy the other bearings separately. Would hate to hold up the whole show because I see one of them doesn't look so good and I dont have a new one on hand. I can always return anything unused if i dont need them. Not trying to be super cheap --- no, i am trying to be super cheap in the sense that i dont want to waste money on things that still look brand new if that is the case.
Replace them. An inner pinion bearing should be replaced anytime it is removed from a gear. It hardly has a shoulder to pull on meaning the roller cage is likely to get damaged and its the main load carrier in the rear end and continually removing it can cause it to potentially spin on the gear.
