local machinist re-sleeved #7 and now #5 is distorted
Old 07-29-2013, 06:36 PM
WideGlide's Avatar
Default local machinist re-sleeved #7 and now #5 is distorted
Iv'e had my LS1 block and heads at a local machine shop in my area. I originally took it in to have the #7 which was cracked re-sleeved , the rest of the cylinders honed and have the heads checked out. Now upon installing the new sleeve he claims the # 5 is distorted by .005'' I guess he had to weld up some cracks before he installed the new sleeve which caused the cylinder next to it to distort. He suggested i bore all the cylinders and get new pistons to correct the problem. But the other cylinders to me looked ok, not really any bore taper or ridge. My question is to anyone that is familiar with machining these aluminum LS blocks is that amount of cylinder distortion gonna throw the piston on the #5 out of alignment enough to cause failure. Could it possibly be honed out to be corrected. btw car is an 02 Z28.
Old 07-30-2013, 04:45 AM
Quick Carl's Avatar
You need to get the cylinder round and that will create too much piston to wall clearance, so like he said you need to get new oversize pistons and hone the other cylinders to match.
Old 07-30-2013, 08:04 AM
96lt4c4's Avatar
.005 is a lot of distortion. Needs to be fixed.
Old 07-30-2013, 08:11 AM
Gunslinger09's Avatar
I'd take the advice of the machinist. 0.01 overbore is pretty common.
Old 07-30-2013, 11:18 AM
WideGlide's Avatar
Default machine work
ok thanks guys
Quick Reply: local machinist re-sleeved #7 and now #5 is distorted
