Oil pressure lower than normal after some hard runs.. Suggestions?
Old 07-30-2013, 08:00 AM
2000SS1979's Avatar
Default Oil pressure lower than normal after some hard runs.. Suggestions?
I just put in my new forged 347 a few weeks ago and got it tuned. Runs awesome. I've got about 250 miles on it now. I have changed the oil 4 times so far.
My oil pressure at idle has always been around 40 and 75 at WOT. I went out to a car meet last weekend and did about 5 or 6 hard runs with the car and now the oil pressure is at 20PSI at idle and Fluctuates from 40 - 45PSI at WOT.
I don't hear any abnormal ticking or other motor noises and the car still has TONS of power.
I changed the oil today to see if it brought up the pressure any and it didn't still idled at 20PSI and was 45ish at WOT. Considering I am spinning my car to nearly 7K RPM I don't think 45PSI is going to work.
Could it be a bad oil pump already? I am open to suggestions of what to check or do next.
Old 07-30-2013, 09:48 AM
2000SS1979's Avatar
Mods can you move to internal engine? I obviously can't read what section I'm posting in.
Quick Reply: Oil pressure lower than normal after some hard runs.. Suggestions?
