Adding Neutral park switch to 95 4l60e
I've installed a LT1 with 4L60E trans out of a 1995 Camaro into a Hot Rod project. The car doesn't have a column or shifter Park/neutral switch and it would be a pain to install one. Question can I install a trans mounted Park/Neutral switch used on trucks etc to this trans that never had one? Is the shifter shaft the same and would it be a direct bolt on? Camaros had P/N switch on the column in 95 I believe.
Trans shifter shaft length, ya that is what I was worried about. I don't have a truck shaft to swap.
