Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Steering wheel shake 60-70 mph
Old 08-01-2013, 12:34 PM
blkgagt94's Avatar
Default Steering wheel shake 60-70 mph
Still on goin shake so annoying first I had nitto nt555 tires has them balanced 3 times still did it well after finding new tires I got Michelins! It still does it wtf!
I have replaced the outer tie rods zo6 end links in between tire swaps an had a alighment gonna get another since I got a new I shaft for steering wheel. I also have a popping noise when I turn the wheel from strut mount? needs replace I'm assuming. Can this be warp rotors? I feel pulse when breaking high speeds
Old 08-01-2013, 12:49 PM
rottnrog's Avatar
I had same problem. Was warped rotor.
Old 08-01-2013, 04:43 PM
blkgagt94's Avatar
You sure like normal driving there fine then high way speeds braking it pulses an normal driving around 60 shakes
Old 08-01-2013, 05:00 PM
NIKDSC5's Avatar
I have never seen it shake during normal driving from warped rotors? That is a shake while braking. Unless they are wayyyyyyyyyyyyy warped.
Wheel bearings?
Ball joints?
Bent rim?
Old 08-01-2013, 07:20 PM
blkgagt94's Avatar
Can't be bent rim cause all balanced fine I'm leaning towards wheel bearings ball joints seem fine
Old 08-01-2013, 08:28 PM
hotstreet's Avatar
I had that issue for a while. Then had a broken ball joint one day leaving for work.
Quick Reply: Steering wheel shake 60-70 mph
