Power to stock rear end??
Old 08-02-2013, 02:45 PM
Thackdaddy43's Avatar
Default Power to stock rear end??
I have a 99 Firebird with the stock rear end in it and I am installing 3.73 gears. How much power can it handle till it gives out??
Old 08-02-2013, 03:14 PM
LILWS6's Avatar
Theres not a power limit on the 10bolt it just has a time limit. Stock motor i blew my 10bolt up so its really not a matter of how much it can take just how long it will take it
Old 08-02-2013, 07:17 PM
Blackpanther99's Avatar
Agreed^ Its about luck in alot of times. Lol
Old 08-02-2013, 08:43 PM
FirstYrLS1Z's Avatar
Autos can put a lot more power to the rear without destroying it because of the absence of the shock load a manual delivers.
Old 08-03-2013, 12:12 AM
Carlos01SS's Avatar
and then there's the tire scenario with that POS factory 10-bolt.
If you have slicks on a 10 bolt, even with a factory motor, just with the slicks you can tear teeth in your differential even in your first hard launch.
that's why most hard core 1/4 runners replace the 10 bolt with an aftermarket axle
Old 08-05-2013, 09:24 PM
So then it would be a good idea to upgrade the axles then??
Old 08-06-2013, 11:23 AM
dalejrfan88's Avatar
Most people say its a waste of time and money to do anything to the stock rear. 9 inch, S60 and 12 bolts are the most popular upgrades. It's not a matter of if it breaks, just when. I am currently saving up for a 9 inch myself.
Old 08-06-2013, 05:11 PM
high n dry's Avatar
stock ls1 power will break it... save the time n money for a S-60 like me!
Old 08-06-2013, 06:04 PM
OK!! Thank you to all that added their help and I think I will be getting a 12 bolt.
Old 08-06-2013, 06:12 PM
HCI2000SS's Avatar
It really depends on your on your luck, how you drive, etc... For example I have the factory 10 bolt with a Detroit Trutrak upgrade, and will probably be making around 550 rwhp in the next day or two here. Am I worried?? Not really because I know how I will drive it. Could it break?? Sure, but that's a justified risk that i'm willing to take at the moment lol
Old 08-06-2013, 10:20 PM
LILWS6's Avatar
I popped a moser 12bolt in mine other than the normal 12 bolt whine shes fine and dandy and i beat her up pretty good
Old 08-06-2013, 10:33 PM
handyandy496's Avatar
Default if
if set up right 12 bolts don't wine or break....12 yrs in a 69 SS 496 chevelle and still going with a box full of time slips . M&H 10x27's too. paid 75 bucks for it in the 80's.
Old 08-06-2013, 11:57 PM
It's going to be a street/strip car and on the street do a little racing here and there
Old 08-08-2013, 09:13 AM
Awake455's Avatar
True, in a car that doesn't have a torque arm twisting and stressing the housing right next to the pinion gear.
A good read: http://shop.brutespeed.com/Brute-Spe...nformation.htm
Old 08-12-2013, 07:33 PM
nice commercial for the 9"'s funny what they don't say is the 9" offsett robs you of tq and hp. Just makes me glad I stayed all GM. @635 hp btw.
As far as the f-body setup vs 4 link....just find a good welder and get more rigidity from the outer ends of the axil tubes (9 or 12 " rears). Don't put all of the pressure on the pumpkin.
Old 08-14-2013, 01:35 PM
Awake455's Avatar
Yes...commercial.
Or it's a vendor that was offering all options for the F-bodies, saw what was happening with the M6 cars, did some homework as to what was going on, and makes recommendations based on evidence.
Your 12 bolt in your F-body is an aftermarket, just as is every piece in these fabbed 9" rears and the S60s but if you feel better telling yourself it's a GM rear axle then yay candy.
Old 08-15-2013, 10:58 PM
dannyz's Avatar
Whoa there gunslinger...
Lets slow down a bit.
Are you an auto trans car, or a manual?
If your a manual, then yes, you should upgrade.
If an auto, you are good down to low 1.5 short times.
Give us some more info..
Quick Reply: Power to stock rear end??
