Were all ls2 engines aluminum?
Old 08-03-2013, 09:20 PM
inSSano's Avatar
Default Were all ls2 engines aluminum?
Guy close to me has a 6.0 for sale. I want an ls2 but will settle for an lq4 or 9. He says its an ls2 but its cast iron with 317 heads. I haven't went to look at it yet but I was under the impression that all ls2's were aluminum. Can anyone help me out with this quick? He said it came out of a 05 Silverado.
Old 08-03-2013, 09:33 PM
madmike9396's Avatar
not all are aluminum some are iron !
Old 08-03-2013, 09:35 PM
inSSano's Avatar
He may have an ls2 than. Are they the same specs?
Old 08-03-2013, 09:38 PM
not sure about specs, but I know the iron block is much stronger than the aluminum. But a little bit more heavy
allan808's Avatar
Ls2 comes out aluminum with 243 heads! an lq4/lq9 is iron with 317 heads!
Old 08-03-2013, 09:39 PM
allan808's Avatar
No ls2 is aluminum!
Old 08-03-2013, 09:43 PM
Originally Posted by allan808
No ls2 is aluminum!
So no ls2 is aluminum ???? Hmmm learn something new every day
Old 08-03-2013, 09:45 PM
inSSano's Avatar
I really thought that they were aluminum still not sure either way. If its an lq4 or 9 it would still work for my project. 700 bucks intake to pan. he's supposed to send me some block numbers we'll find out for sure. I thought 700 for an ls2 was too good to be true.
Old 08-03-2013, 09:47 PM
so what is this ??? http://www.texas-speed.com/p-578-gm-...ls2-block.aspx
Old 08-03-2013, 09:48 PM
allan808's Avatar
Its about 100 lbs heavier.
Old 08-03-2013, 09:49 PM
allan808's Avatar
Its an aluminum block!i dont see it iron do you?
Old 08-03-2013, 09:52 PM
allan808's Avatar
What? I said the ls2 is aluminum!
Old 08-03-2013, 09:56 PM
pretty sure some are iron as well ! think they put the iron 6.0s in the trucks and hummers and larger vehicles
Old 08-03-2013, 10:04 PM
either way that's not a bad price if its not messed up
Old 08-03-2013, 10:08 PM
inSSano's Avatar
Yeah i'll just have to check it out and hope for the best. I'll at least have it on the stand to work on abit at a time.
Old 08-03-2013, 10:14 PM
coming from a 05 it would probably be a LQ9 or LQ4 I think the lq4 has dished pistons and less compression and coming out of a truck it will more than likely be a iron block.
"Technically" I think all ls2s are aluminum but the lq9 and lq4 are iron and have the same bore so you could just call it a ls2 no big deal
Old 08-03-2013, 10:42 PM
allan808's Avatar
The lq9 is flat top pistons, the lq4 is dished and the only difference between the ls2 and lq9/lq4 is the ls2 is aluminum and about 100lbs lighter.
But be aware they are the same but at 100lbs heavier youl notice the car in turns etc will have more sway. Honestly ill go for the 100 lbs lighter then having a little stronger block!
Old 08-03-2013, 10:46 PM
allan808's Avatar
Dude if you save a little more you could find an ls3 shortblock on ebay, i did! got one for $1800 brand new unassembled with rings and bearings! look up ebay seller kbees he usualy has one once a month for sale.
Old 08-03-2013, 11:40 PM
Josh18Fan's Avatar
LS2 = Aluminum block, 243 aluminum heads.
LQ4/LQ9 = Iron block, 317 aluminum heads.
Old 08-04-2013, 06:53 AM
that was a good find
Quick Reply: Were all ls2 engines aluminum?
