turbo 6.0 blowthru on alk
How much am i looking to spend on a blow thru carb? Looking to run alcohol. What are my options. C and S? Considering going to efi but wanna explore my options.
Im running a CSU e85 blow thru carb. They are around a grand with single needle bowls but on e85 im limited to about 850hp so on methonal you would be a little less. Setup with dual needle bowls they are around $1500.. And my carb worked flawless right out of the box with only a squirter change of one size. Ive also found running a blow thru setup you need to run more timing than the efi guys.
