LS3 E-Force conversion still wont start
Well I am still in the same boat. The car still wont start after I got my 2nd
E38 computer from PSI. The car will crank and backfire but wont start. I am getting a P0335 error code on my scanner. I have replaced the crank sensor and checked the wires back to the ECM connectors. I have 12 volts when key is on and cranking. I have fuel pressure and spark. Any ideas would be great as I am about to throw in the towel.
Thanks,
Jeff
This is a LS3 with an E-Force blower from a 2010 Camaro SS. The Harness and ECM are both from PSI. All sensors are new (Crank, cam, maf).
Thanks,
Jeff
