Turbo cam selection: Tick?
Old 08-08-2013, 12:57 PM
Centipede Performance's Avatar
Default Turbo cam selection: Tick?
I have a truck with a 6.0 swap and 4L80e. The engine has L92 heads and intake and some PRC valve springs. It is getting an S488 turbo with the 96mm exhaust wheel. The converter is a 3600 stall and it has 3.73 gears. I plan to use premium fuel and some methanol. What would be the best cam to use and why? I have been slowly putting this truck together for a long time so I want to make sure I get a good cam the first time. Thanks!
Old 08-08-2013, 01:00 PM
mrstepheneades's Avatar
Martin from Tick will chime in shortly im sure with all the knowledge and info you need.
Old 08-08-2013, 02:30 PM
Blackpanther99's Avatar
Call Martin at Tick or just wait for his post
Old 08-08-2013, 02:55 PM
turbocamaro125's Avatar
Ive been using LIL John for all my turbo ls stuff....works great and sounds good! 4 cams and counting with LJMS
Old 08-08-2013, 02:59 PM
I'm open to suggestions from anyone! Martin@Tick just seems to be the go-to guy for cam advice around here
Old 08-08-2013, 03:01 PM
cause Martin is a sponsor....but check out Yellow bullet John knows his **** too
Old 08-08-2013, 03:06 PM
Okay, I'll be sure to give him a shout. Thanks!
Old 08-08-2013, 03:25 PM
Yup, Liljohn knows his stuff as well.
Old 08-08-2013, 03:56 PM
bwolfZ28's Avatar
I've gotten 2 custom cams from Martin at tick performance. Give him a call and you wont be disappointed.
Old 08-08-2013, 05:03 PM
Firehawk441's Avatar
What would be the best cam to use and why? I want to make sure I get a good cam the first time. Thanks!
http://www.briantooleyracing.com/
Call this person.
Old 08-10-2013, 01:11 PM
Sales@Tick's Avatar
226/235 .605"/.610" 113+6
Don't need a big cam for a truck, especially with a L92 with an intake port you could nearly put your fist into. This will do everything you want and some.
I'd also be more than happy to discuss your cam with you on my personal cell number this weekend or on Monday or next week at the shop. Don't be a stranger!
Old 08-10-2013, 10:23 PM
wild1100's Avatar
Tick is great just finished setting motor in my car. can't wait to see how it reacts I'm running a 408 with a rear Mount setup. Great customer service and fast shipping
Old 08-10-2013, 10:59 PM
Sales@Tick's Avatar
Was this the 237/237 cam I did? GT91 rear mount?
Old 08-11-2013, 06:47 PM
wild1100's Avatar
Yes sir that's her
Old 08-11-2013, 10:20 PM
Sales@Tick's Avatar
I normally don't like rear mounts, but with a 408, a T4 turbo with a 97mm turbine wheel, .96 AR housing and a cam on the smaller side(237/237 114 iirc) it should run very well.
Old 08-11-2013, 10:51 PM
Isn't that a big cam? My friends camaro has cam like that and its pretty big lol.
Old 08-11-2013, 11:25 PM
itsslow98's Avatar
Not big for a 408.
Old 08-12-2013, 04:43 PM
Yup^ not big at all.
Old 08-12-2013, 05:43 PM
Sales@Tick's Avatar
Nope, not for a 4" stroke 408. It's actually on the smaller side for a 408. I have 346-364 with cams nearly that big in them with S475-S480 turbos. Granted they are more track cars than street cars, but they're still "street" cars.
Old 08-12-2013, 08:22 PM
yenkm68's Avatar
Martin set me up with this same cam for my nova last week, should be here in the next few days and in by the weekend if everything goes as planned
Quick Reply: Turbo cam selection: Tick?
