357CI Forged LT1
357CI Forged LT1
Category: Engine - Complete Motors
Price: $2500
Location (State): SC
Item Condition: Used
Engine: LT1/LT4
LS Engine?: Non-LS Part
Will sell everything at once as well.
Lt1 block
stock reconditioned GM crank
forged sealed power pistons
forged scat rods
arp rod bolts
New oil pump and pick up tube
custom grind camshaft from advanced inductions
LS7 lifters
stock length hardened pushrods
crane 1.6 gold roller rockers
comp springs
Heads are Aluminum GM castings with slight port work
arp head bolts
Mr. Gasket .026 head gaskets
Ported and powdercoated LT1 intake
egr block off plates
aftermarket 58mm throttle body
SVO 30# injectors
Aftermarket valve covers
fuel rail covers
3.5" MAF
Corvette twin style air filter
MSD Cap and rotor button
cloyes double roller
STOCK GM opti, no junky aftermarket
OBD II timing cover so can be used in 93-97 engines
CSR Electric water pump
Speed Inc Alternator relocation kit
corvette starter
Several new sensors as well as all needed sensors
Tuned PCM will come with motor if bought complete.
Engine is in a 1995 caprice and has ran 87mph in the 1/8th mile. Should see 93-94 mph in an f-body.
If you have any questions please message me!!!!
