C6 grandsport wheels on 99 ss
Old 08-12-2013, 07:16 PM
jfroh1992's Avatar
Default C6 grandsport wheels on 99 ss
I picked up my 99 ss about a year ago and ever since Ive wanted to get wheels for it. i like the look of the stock zr1s but wanted something more uncommon.
I started looking for a set of c6 z06 spyders but after coming across a very good deal on low mile take off grandsports i couldnt pass it up.
before picture
I knew it would take alot of work to fit once i opened the box
test fitting
after
Old 08-12-2013, 07:44 PM
BlackBetty99SS's Avatar
Very nice look! Works very well w the red. What size tire did u go w in front/rear?
Old 08-12-2013, 09:44 PM
jfroh1992's Avatar
275/35 up front
325/30 in the rear
Old 08-12-2013, 09:55 PM
LS2GS's Avatar
What kind of spacers did you use to make the rims fit?
Old 08-12-2013, 10:49 PM
jfroh1992's Avatar
It currently has a 1/4" spacer on only the right side because the rear isnt centered. Once my adjustable panhard bar shows up no spacers should be needed.
I did need to get offset lcas and i ground down some of the high spots around the bumpstops. Bumpstops are still there for now.
Old 08-12-2013, 11:10 PM
Cajun ELESS-ONE's Avatar
looks nice. needs more low now.
Old 08-12-2013, 11:34 PM
jfroh1992's Avatar
Thanks, I really like how it looks now. Ill be ordering some strano springs very soon these wheels make it look even higher
Old 08-13-2013, 07:25 AM
Brutal Boba Fett's Avatar
No BFH or fender rolling needed?
Old 08-13-2013, 07:51 AM
Furious1's Avatar
Looks good!
Old 08-13-2013, 08:31 AM
Ballzee's Avatar
that looks really good.. glad to see something diff
Old 08-13-2013, 09:31 AM
jfroh1992's Avatar
Yea I needed to bfh but not really as much as I thought I would have to. Fenders are fine right now because I'm still at stock ride height. I'm sure they'll need to be rolled once I lower it
Old 08-13-2013, 07:17 PM
38DD2436's Avatar
See how it looks by lowering the front first. The rear doesnt look too bad.
Old 08-13-2013, 08:35 PM
jfroh1992's Avatar
Ill be doing Strano springs all around pretty soon but ill have to set it on the ground before I do the rears to see how it looks
Quick Reply: C6 grandsport wheels on 99 ss
