Water pump pn#
Water pump pn#
looks like I gotta replace my squeling water pump finally. Could I please get some imput on the part numbers please. More specificalythe pump that some of you have used that weren't for the V and worked. Not really looking forward to a 200+ for a water pump if a corvette's or similar fits. Also roughly how much coolant should I get for the system. Thanks in advance
Pick up the LS3 water pump. Interchangeable with ours and has less rotating mass if your car has one of the older style pumps. You can usually find brand new ones pulled off GM crate motors for less than $100.
Thing to note about the LS3 water pump, from what I've seen it seems there are some with the outlet on the drivers side of the car and some with it on the passengers side. My dad picked up a new take off and the outlet is in the drivers side so to make it work he will need to come up with different upper radiator hose.
Well i was gonna do A little more checking to make sure it is the water pump but i think i got my answer. As i pulled into my driveway i smell coolant. Park and go to see what it is. Coolant all over the engine bay. And a nice little puddle under the car. Yay. Also any chance the coolant could mess somthin in my engine bay up other than the smell
