Does anyone repin PCM's?
Old 08-13-2013, 04:35 PM
Y2K_Camaro's Avatar
Default Does anyone repin PCM's?
My buddy is looking to switch his PCM in his '98 Z28 for a 99+. I hear there is someone on here you can send a PCM to that will repin them to fit the '98 harness. Any help would be appreciated. Is there is anything else that needs to be done with this PCM swap? Like sensors, etc.
Old 08-13-2013, 05:26 PM
LSX Power Tuning's Avatar
We have re-pinned 98 harnesses to make them use a 99+ pcm but never heard of someone re-pinning a 99+ pcm to work on a 98 harness.
Old 08-13-2013, 05:49 PM
MontecarloDrag's Avatar
It is doable, however the internal pins in the PCM are rigid and can't be changed from one position to another. To do it a lot of wiring and soldering is required.
It's much easier to re-pin the harness
Old 08-13-2013, 07:05 PM
9-Second Club
Ed Wright's Avatar
I'd hate to tackle that one. LOL
Old 08-14-2013, 04:54 AM
Exidous's Avatar
Definitely suggest you repin the harness. WAY easier. I've been there with my motor swap.
Old 08-14-2013, 07:19 AM
Y2K_Camaro's Avatar
Hum, ok. Well I have no idea how to repin a harness. I'll have to let my buddy know whats up. I'm sure there's a chart, thread or something floating around this forum on how to do it. Is it literally just repining the harness that goes into the PCM? Or is other stuff involved?
Old 08-14-2013, 08:56 AM
therealcreeper's Avatar
http://www.ls2.com/boggs/torques/98pinpcm.htm
99+:
http://www.mrk-motorsports.com/pdf/9...%20Pinouts.pdf
Just unplug the connector, remove the covers from the harness plug and pop each pin out and into the correct new position. Not sure exactly what else is involved.
Old 08-14-2013, 01:07 PM
This is a PCM from inside
The pins can't be changed from it's original position so you need to do a good soldering job using special wire to change their arrangement.
I have not done it for a PCM but I have done it for other devices with much less pins and it's still a PITA. I would never do it because there's no reason.
I prefer to repin 10 harnesses than 1 PCM.
Old 08-16-2013, 11:50 AM
Y2K_Camaro's Avatar
Thanks guys, hopefully I can search for some more answers. Thanks for posting those 2 links, that's the most important part lol.
Damn! The inside of that PCM looks like a complete pain! No way lol, harness it is.
Old 08-19-2013, 08:13 PM
Street Racer's Avatar
Here ya go http://www.mrk-motorsports.com/pages/store.html
Old 08-19-2013, 09:43 PM
That's just a 411 PCM with the fuel segment swap done, we sell those also, it's nothing special.
Old 08-20-2013, 12:34 AM
On the home page they say they are working on a hot swap project for 97-98 pcm. The only thing needed for swap will be the pcm no harness change needed anylonger...but they also have the repin directions on site as well.
Old 08-21-2013, 03:59 AM
Y2K_Camaro's Avatar
Awesome! Thanks guys.
Old 04-28-2016, 09:02 PM
Smoky02's Avatar
I know this is an older thread. But what do you do with the extra pins?
Quick Reply: Does anyone repin PCM's?
