How to clean old headlight lens?
I have a headlight that is needing cleaned up. It's a brownish color tint with some scratches on it that need to be buffed out,what do you suggest using to buff it out and to make it look new again?
Go on down to the auto parts store and look for some Blue Magic plastic and plexiglass cleaner. If you can't find that look for some Brasso, they are basicly the same thing Brasso just has components to remove oxidation. Just pour some on a cloth rag and start rubbin. If it's real bad, get some 2000 grit wet sand paper and gently go over it a few times until the discoloration is gone. Don't worry about the 2k grit scratching it cause that'll buff right out w/ the polish.
