95 fuel gauge stuck at full level all times
Old 08-16-2013, 12:56 PM
SPOOLED UP's Avatar
Default 95 fuel gauge stuck at full level all times
Even when I disconnect the sender wire to the pump and or ground it.
The gauge never moves. But today I stuck a wire in the cluster and moved the level pointer all the way to empty and truned the car on. It went immediately to full. With the sender disconnected. WTF????
What causes this and how to fix it?
Purple wire on the sender is disconnected and its still full.
Cluster bad or shorted to ground on fuel level side only?
Old 08-16-2013, 01:06 PM
Village Troll
SS RRR's Avatar
From Shoebox's website:
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
Have you changed out the fuel pump?
Old 08-16-2013, 02:05 PM
SPOOLED UP's Avatar
Yes and I'm thinking th float might b stuck on full but not sure
Old 08-17-2013, 12:50 PM
Village Troll
SS RRR's Avatar
Did you put the new pump back into the fuel bucket or just hose clamp it to the bracket?
Old 08-17-2013, 09:33 PM
SPOOLED UP's Avatar
lol found it.
bad ground.
fixed the issue
Quick Reply: 95 fuel gauge stuck at full level all times
