LPW rear girdle install
Old 08-17-2013, 08:50 AM
Z28SLPCAMAROZ28's Avatar
Default LPW rear girdle install
So I'm going to be installing a LPW rear-end girdle today and have a couple questions before I do this. Yesterday I had jacked my car up to paint rear calipers and noticed two brackets bolted under the rear cover mounting bolts. So I dug out my installuniversity guide and saw his TA girdle came with two longer bolts for that spot. Checked my bolts and they are all the same length. What should I do to fix this? Just put in all 10 of the bolts supplied and hope they're long enough?
Old 08-17-2013, 11:38 AM
Valkyn's Avatar
Just go to a hardware store and get some longer bolts if the supplied ones are too short.
Old 08-18-2013, 12:40 PM
Well, as I suspected they were too short. So know I have to wait till Monday when Fastenal is open to get my extra 2 bolts. I've got all the bolts torqued on so after this I should be ready to go.
Old 08-18-2013, 07:57 PM
Before I go and buy any bigger bolts, (which will be like 2 days because online it says my local fastenal doesn't have them) does anyone know if I can just wire-tie the e-brake tubes to the axle tubes? They're wire-tied to the panhard rod so does it really matter?
Old 08-19-2013, 04:15 PM
Nobody knows if I can do this or not? They are pretty stiff and already rest on the axle tubes anyways....
Old 08-20-2013, 11:25 AM
sicksspeed's Avatar
Sure you can tie the emergency brake cables to the axle. Just make sure it dosn't stretch or rub.
Old 08-20-2013, 03:59 PM
Thanks, I figured I could... It looks like they're in a pretty thick rubber sleeve.
Quick Reply: LPW rear girdle install
