aftermarket fuel rails pointless with stock lines??
Old 08-17-2013, 04:26 PM
vbls's Avatar
Default aftermarket fuel rails pointless with stock lines??
ok I have a fast 92 intake and im about to get the FAST rails also, I know that they have a fitting to connect the stock lines to a -6. is it pointless to buy aftermarket rails if the lines are still stock?
Old 08-28-2013, 09:57 AM
skinnies's Avatar
How much power you trying to make, we have done over 850rwhp on stock rails on e85 on a few cars.
Old 08-28-2013, 08:41 PM
Blackpanther99's Avatar
Not pointless. It depends on your setup.
Old 08-31-2013, 04:31 PM
mebuildit's Avatar
If you measure the ID of the stock feed fuel line it has the same inside diameter as a -8 fitting. Most people go with the -6, I went with -8 on my car with no troubles. Might look into it.
Old 09-01-2013, 01:29 AM
Burken01's Avatar
To be honest they will be a "bling" item on a NA car.. Even most boosted cars don't need them...
Quick Reply: aftermarket fuel rails pointless with stock lines??
