Trucks in the shop getting this installed...
what a rush!
the set up goes like this:
Clifford Avant Gaurd 5 Alarm
Remote start
Blackjax anti car jack
Front Windows up/down/cracked
Rear Windows up/down
Daul Zone Proximity Sensor
Daul Zone Shock Sensor
Tilt Sensor
Hood Pin
Eclipse Eclipse AVN 2454 HU
DVD Navigation
DVD
CD
Back Up Camera
JL 1000/1 amp
JL 300/4 amp
Boston Pro 10.5 LF subs
Boston Pro 6.5 Components Front
Boston NX6 Two Way Rear
1 Farad Capacitor
Custom Fiberglass Box to mount behind rear seats
ISOX's Cables and wiring kits
Dynamat Extreme entire Cab and Doors
well that's about it, if anyone is interested in pics when its done I'll post some for ya!
Remote start
Tilt Sensor
Hood Pin
DVD Navigation
DVD
CD
Back Up Camera
JL 1000/1 amp
JL 300/4 amp
1 Farad Capacitor
If they haven't put the cap in yet, don't they are a waste of time unless you have about 10 farads for your setup. Just put a optima yellowtop under the hood. That one farad is good for about 100 watts, and you already are using a JL1000/1 which has a regulated power supply, as long as the Voltage doesn't go under 11.5 the cap will not be doing a damn thing anyway.
Tell them to upgrade the factory grounds under the hood. You might want to think about changing your alternator to a higher amperage unit. We install jl1000's all the time and if the vehicle can't supply that amp with 100amps of current it will constantly go into voltage protection and not play. Something to ask about.
