FS: 1998 Formula
FS: 1998 Formula
Year: 1998
Make: Pontiac
Model: Firebird
Price: $6500
Mileage: 108000
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
http://www.youtube.com/watch?v=sdIcL...ature=youtu.be
Car has the following mods:
Engine:
-SLP Lid
-Ls6 Intake
-Ported and Polished Throttle Body
-Under drive Pulley
-Texas Speed Ms3 cam 237/242 112 LSA
-PRC .650” dual valve springs, titanium retainers, seats, locks, valve seals
-7.40 Pushrods
-Ls6 timing chain
-Racetronix fuel pump
-MSD plug wires with NGK TR55 spark plugs
Exhaust:
-Hooker 1 ¾ headers
-Mufflex 3 inch Y pipe
-Flowmaster merge
-Stainless Moroso Spiral Flow
Wheels:
Fronts 15x3.5 Greg Welds
Rears 15x10 RaceStars with 275/60/15 Hoosier Drag Radials
Suspension/Rear end:
-Spohn Driveshaft Loop
-Lakewood Lower Control Arms
-Welded in lower control arm relocation brackets
-Motive 4.11 gears
-Thunder Racing rear end girdle
-ARP Rear Wheel Studs
-Hawk ceramic brake pads
Transmission:
-FTI converter
-Local built 4l60e transmission
-Truck pan on transmission for extra fluid capacity
-Transmission Cooler
Misc:
-OEM ram air hood
-Spare 3.23 rear end
Things to note:
-Converter and transmission have under 250 miles on them, both new this year
-I have the front license plate cover, just not on the car.
-Security light flashes due to VATS being disabled.
-Gas gauge doesn't work
-Abs and traction control doesn't work due to 28" tires
-Car throws a cam sensor code every once in a while, this doesnt effect anything except causing a longer starting crank.
-Has a scuff mark on the bumper from previous owner (See Pic)
