Do the precision vband in exhaust housings limit power compared to a t4?
Old 08-19-2013, 11:46 AM
single digit dreamer
parish8's Avatar
Default Do the precision vband in exhaust housings limit power compared to a t4?
Plan is a pair of 6766 turbos on a 408 at 1000+hp.
I like the compact vband in exhaust housings but could fit t4's. will the smaller appearing vband housing be a restriction?
Old 08-19-2013, 02:49 PM
sr71bbjr's Avatar
Not at 1000 wheel. They v band housings are a .82 AR which is smaller than whats available on the t4 housing. Which i believe is .96 and goes up to a 1.32.
I made 1105 rwhp in my vette with a pair of 6265's and v band housings. If i were to build a kit toady i would without a doubt go with the t4 housing if you have the room. I just had to redo my entire kit cause i built a big motor and the .82 AR wasn't going to work well with a 430 ci.
Old 08-21-2013, 10:26 PM
LS1NOVA's Avatar
I think so.
Old 08-22-2013, 12:37 AM
black98ws6ta's Avatar
A smaller exhaust a/r will almost always cost you power(but make it spool better). A larger exhaust housing means more flow and less back pressure. Which also usually allows more timing, and more power. A/R is just a ratio of area, the v band inlet housing is considered T3 sized. A T3 and T4 housing could have the same A/R but the T4 flow much more.
I have a customer with a 402/small cam/small head and a pair of vband 6766's and they spool very fast and it makes 900 wheel through an auto at 20 psi on e85
Old 08-22-2013, 03:30 AM
stevieturbo's Avatar
Ive been researching various TT related stuff lately.
And as far as I am aware, their V-Band housings are all based on T3 units, so is unlikely they will be anywhere near ideal, especially for a bigger motor.
The Tial ones go to much larger A/R's although may not fit those turbos.
Old 08-22-2013, 05:54 AM
LS1NOVA's Avatar
They do make for one hell of a street car though, insta spool on a 427.
Old 08-22-2013, 06:40 AM
LS1 240sx's Avatar
I thought Turbine housing have just a air ratio for spool/tuning purposes, from what I learned the turbine wheel is what allows more flow ONLY.
Old 08-22-2013, 06:47 AM
No.
If you use a very small A/R housing, it only has a tiny hole in it. A housing with a large A/R has a larger hole, hence slower gas velocities into the turbine so less spool. But more flow at the top end.
So it's a balancing act finding what works best overall for each user.
Old 08-22-2013, 06:51 AM
LS1 240sx's Avatar
No.
so the turbine wheel wouldn't hurt you if it was small? just run a large a/r with the small turbine?
Old 08-22-2013, 07:03 AM
Yes it would.
But if you used a huge turbine with a minute A/R, then the turbine housing would be the restriction.
As I said, it's a balance between them all.
If you choose a turbine wheel that is too large, you'll never get it to spool
Old 08-22-2013, 07:16 AM
LS1 240sx's Avatar
Yes it would.
Gotcha
Old 01-18-2014, 05:05 PM
toretto's Avatar
I hate to bring this back from the dead, but I have been curious as to why people say the Vband Flange is like a T3?
The inlet area is 6.447 compared to 5.98 on a T4 Non Divided flange.
So IIRC, the .81 T4 flange should be tighter on flow that the .82 THV housing.
Does that make sense? Also there are 2 different ARs now, the .63 and .82 housing.
Old 01-18-2014, 05:19 PM
Because the area doesnt relate to the flange. It's further down the scroll.
The V-Band housings in this case are based on T3 scrolls.
Old 01-20-2014, 12:04 AM
The t4 flange is much larger then the "t3 sized" v-band inlet housings. Precision also calls them "t3 sized".
Old 01-20-2014, 08:15 AM
Fathouse's Avatar
Pte is coming out with a t4 based vband housing soon. For the 75mm sized turbin wheels.
Old 01-20-2014, 08:21 AM
rotary1307cc's Avatar
Just go look at the gt35 turbine maps if you want an idea of how much the A/R of a housing changes the mass flow of a certain turbine
Old 01-20-2014, 03:23 PM
GR8GAME's Avatar
My turbo from BEP has a V-banded exhaust inlet with a 1.30 a/r... S475
Are you guys specifically talking about much smaller turbos?
Quick Reply: Do the precision vband in exhaust housings limit power compared to a t4?
