need help with these dtc codes
Old 08-19-2013, 05:59 PM
blk96z07's Avatar
Default need help with these dtc codes
Yall I'm kinda lost on these dtc codes..
I bought a 94 formula with a blown engine, I replaced it with a 96.. used all the wiring,pcm that came with the 94. Replaced the optispark, wires, plugs, optispark harness also. This is some background on the car.. car ran fine had a lil miss so I went ahead in checked the codes n I tell u I was like Wtf ok heres the list
14
42
43
44
45
51
53
55
Ok so theres the list I Need advice
Old 08-19-2013, 10:18 PM
shbox's Avatar
Clear the codes (they could have been there a while), see what comes back and note what your system voltage is.
Old 08-20-2013, 06:26 PM
blk96z07's Avatar
I have tried several times n for some reason the codes will not clear... I had AutoZone check my battery and alt n the system was at .14.4 if memory served me correct! Lol
Also I had put a new o2 sensor when I put the car back together. What really gets me is the 51 code.
Old 08-20-2013, 06:33 PM
9-Second Club
Ed Wright's Avatar
Your not going to easily cure 51 by clearing it. That is a checksum error. Corrupted calibration error or one of the two flash chips failing.
Old 08-20-2013, 11:11 PM
camaro1975's Avatar
what kind of scanner are you using?
i bought and then returned a innova scanner awhile back and it gave me all the wrong codes. I ordered one of the obd1 usb cables and used datamaster on my laptop to scan it and instead of having 9 codes that made no sense i only got 4 codes.
Old 08-22-2013, 01:15 PM
blk96z07's Avatar
it was the same scanner u had. But it works fine on my lil bros mustang with no problems so idk
Old 08-22-2013, 03:39 PM
shbox's Avatar
IDK what is up with the Innova scanners, but I have seen lots of people with weird results from them. I'd use something else.
Old 08-22-2013, 05:15 PM
blk96z07's Avatar
I done see a few different post where them innova scanners r junk. What I'm gonna do is swap the pcm out with another this weekend n see if anything changes... Now I do have a 52 mm throttle body n bbk shorties on the car now. Do u think that the bbk suck n burning up them new 02 sensors? Because I'm gettin a lean n rich code which is weird to me. I done checked everything else I been throwing parts at it since day one. Also this is my first ob1 car n I been lookin into buying a USB n get some software to look over anything. Which would be the best to get?
Old 08-22-2013, 10:55 PM
camaro1975's Avatar
http://www.aldlcable.com/sc/details.asp?item=aldlobd1u
I'm pretty sure this is the one you need. Maybe someone else can chime in to help confirm.My car is a 94 with OBD1 and this was the cable i needed.
Quick Reply: need help with these dtc codes
