Head shaving question
Old 08-20-2013, 08:50 PM
LT14LIFE JT's Avatar
Default Head shaving question
I'm doing a cam swap on my '95 Z28 I just picked up. I'm planning on shaving the heads to pick up a few points of compression. What is the maximum amount of material I can remove and still retain a decent piston to valve clearance with an aftermarket cam? If anyone has any insight, thanks in advance.
Old 08-20-2013, 09:08 PM
9-Second Club
Ed Wright's Avatar
You HAVE to check your valve-to-piston clearance after the cam is installed to know how much the heads can be cut. The iron head LT1 head gaskets are a popular deal which usually puts them to about 11.5-1. Depends on the cam whether you have enough valve-to-piston clearance to use them.
Old 08-21-2013, 08:09 AM
Village Troll
SS RRR's Avatar
I thought Impala gaskets bumped up the compression to maybe 10.8 on stock block/heads?
Old 08-21-2013, 08:38 AM
bufmatmuslepants's Avatar
0.026 gaskets put you at 11:1 on unmilled heads, milling 0.010 puts you at 11.8:1.
Old 08-21-2013, 11:20 AM
9-Second Club
Ed Wright's Avatar
I stand corrected. Never measured it myself. Just going by what kids tell me. They probably read it on the Internet. Should not comment when I don't actually know. :-(
Old 08-21-2013, 11:30 AM
Village Troll
SS RRR's Avatar
I'd rather hear it from you from hearing/reading it than most anyone else, dear sir.
Old 08-21-2013, 11:53 AM
I'm using 54cc heads, 0.05" stock gasket, 4.030 gasket bore, 4" bore, 3.48" stroke, -7cc pistons, 0.022" in the hole, getting 10.43:1 stock compression ratio. Changing gasket thickness to 0.026 gives 11.09:1. With impala 0.028 gaskets its 11.03:1. Am I doing something wrong or are you just being an old fart? I meant 11.5 not 11.8 if milled 0.010 but yes that was using someone else's calculation I read on the all knowing Internet, that flat milling each 0.006 = 1cc, rounding up to 2 for 0.010, calculates to 11.47:1.
Old 08-21-2013, 12:06 PM
Village Troll
SS RRR's Avatar
Originally Posted by bufmatmuslepants
-7cc pistons
Stock pistons?
Old 08-21-2013, 12:15 PM
Originally Posted by SS RRR
Stock pistons?
Assuming stock, but I keep seeing anything from 4-7cc for stock pistons and 0.022-0.033 in the hole, either way, with a baseline of 10.4:1 and changing nothing but gasket thickness, you get 11:1 with 0.026 or 0.028 gaskets.
Old 08-22-2013, 05:37 PM
Thanks for the input guys. I'm trying to get the most out of a cam swap without buying aftermarket heads and wanted make sure shaving the heads was worth the effort/costs. Question #2: Does anyone know what gains I can expect from shaving my heads .010/gaining compression? ETs or dyno #s are appreciated.
Old 08-22-2013, 06:50 PM
RamAir95TA's Avatar
It is unlikely anyone would have that data. I can tell you it'd be worth a handful of HP, maybe 3 or 4, on a stock engine. A bit more with a cam swap.
Old 08-23-2013, 01:53 AM
cardo0's Avatar
If u can calculate your cr ratio and cr ratio increase then u can use this D. Vizard chart in this Popular Hot Rodding article to find your percent power gain: http://www.popularhotrodding.com/tec...on_ratio_tech/.
Good luck,
cardo
Old 08-23-2013, 06:28 AM
9-Second Club
Ed Wright's Avatar
Good luck,
cardo
Often doesn't work that way in the real world. Too many variables. Vizard is kinda "out there". :-)
Old 08-23-2013, 06:36 PM
Thanks again guys. I appreciate the info. I'm planning on using a little nitrous and I'm glad to hear that I'll be at least 11.0:1 CR to make the nitrous more optimal. Heads are coming off this weekend and headed to the maching shop for milling. Let the fun begin.
Old 08-23-2013, 07:19 PM
cardo0's Avatar
I ' d r a t h e r h e a r i t f r o m y o u f r o m h e a r i n g / r e a d i n g i t t h a n m o s t a n y o n e e l s e , d e a r s i r. B u t D . V i z a r d m e n t i o n s h o w i t c a n v a r y i f y o u h a d b o t h e r e d t o r e a d t h e a r c t i c l e.
c a r d o
Quick Reply: Head shaving question
