one or two 450 walbros e85 pumps
Old 08-20-2013, 10:17 PM
TT402LS1's Avatar
Default one or two 450 walbros e85 pumps
Twin turbo 6.0. Looking to make around 800rwhp on E85. I got 80lbs injectors. Plan on running a 75-80lbs base pressure. Boosting 16-18psi
Old 08-20-2013, 10:46 PM
ws602's Avatar
What is it going in ?
Old 08-20-2013, 11:06 PM
slowlsx's Avatar
Interested if anyone has done dual 450s if so id like to see pictures!
Old 08-20-2013, 11:17 PM
ws602's Avatar
Check out squash performance set up
Old 08-20-2013, 11:23 PM
TT402LS1's Avatar
67chevelle
Old 08-20-2013, 11:28 PM
HRHohio's Avatar
Nice! What turbos are you going with?
Old 08-21-2013, 12:01 AM
TT402LS1's Avatar
Bought some turbonetics 62mm's. .68ar
Old 08-21-2013, 03:28 AM
ittwgn's Avatar
yes mate I run dual 450lph pumps in a 4 litre surge tank setup !!!! this pic is of the old 225lph pumps as far as I am aware they are the same size so same thing !!!! cheers
Old 08-21-2013, 08:51 AM
TT402LS1's Avatar
Nice setup. What hp you at? What size injectors?
Old 08-21-2013, 09:57 AM
slowlsx's Avatar
I beleive martin is running the squash dual 450's with -10 feed and FIC 160's. He said it is good for 1300rwhp on the corn and 1600rwhp on gas. Im really considering the squash set up over a magnafurl 4303
Old 08-21-2013, 05:42 PM
TT402LS1's Avatar
I need a setup for 67 chevelle. Im looking at Tanks Inc. They do Walbro in tank w/ baffle, and stock looking tank. Anyone know if you can run E85 in a galvanized tank? Theirs are galvanized inside and powder coated outside.
Old 08-21-2013, 09:37 PM
baggins's Avatar
Ittwgn- who.makes that surge tank?
Old 08-22-2013, 03:18 AM
ittwgn's Avatar
hi mate i'm at 1004rwhp , id2000cc injectors , dual 1/2 lines from surge to rails, turbosmart fpr2000 regulator !!! baggins here,s a link from Australia
http://www.aseturbo.com/FUEL-SYSTEMS.../prod_276.html
Old 08-22-2013, 01:17 PM
TT402LS1's Avatar
So no one answered my question. One or two pumps for my setup?
Old 08-22-2013, 01:18 PM
TT402LS1's Avatar
Nice fuel setup ittwgn! Out of my price range though.
Old 08-22-2013, 04:28 PM
Slow94Formula's Avatar
You will need two. It looks like about 73-75 psi would be the most efficient if you will run all of that 18psi to meet your power goal with the 80's. That would bring your fuel pressure up to 91-93 psi at which point those pumps should be able to give you almost 950 rwhp worth of e85. Therefore 800 should be doable... The only problem is that those fuel pumps really start to fall off on flow numbers after about 80 psi if you look at the flow chart.
Old 08-22-2013, 07:15 PM
TT402LS1's Avatar
Wow. Thanks! Where are you getting this info? Would like to see the flow numbers myself. I really appreciate your input!
Old 08-22-2013, 07:17 PM
TT402LS1's Avatar
Oh, that what I was wondering. If they would perform at that psi (fuel)
Old 08-22-2013, 07:20 PM
GMCtrk's Avatar
My single 450 is maxed out at 12 psi 6.0
Old 08-22-2013, 07:24 PM
TT402LS1's Avatar
Thanks GMCtrk, this is the info im looking for.
Quick Reply: one or two 450 walbros e85 pumps
