1998 Camaro Low Pressure
Old 08-23-2013, 05:26 AM
nascarnate326's Avatar
Default 1998 Camaro Low Pressure
My 1998 Camaro Z28 has 35lbs of pressure at the fuel rail.
Has a Granatelli 255 fuel pump.
My question is: Should I replace the regulator first?
Do I need to replace the whole assembly(expensive) or just the pump(less expensive)
What are the differences on the 98 vs 99+?
Old 08-24-2013, 03:46 PM
jrpimp00's Avatar
id verify with another gauge. Then the regulator would be easiest to change but we (98s) have completely different tanks and assemblies
Quick Reply: 1998 Camaro Low Pressure
