404 ls stroker pistons wont clear reluctor wheel
Old 08-23-2013, 07:27 PM
blackLS1m6's Avatar
Default 404 ls stroker pistons wont clear reluctor wheel
Having trouble putting a 404 stroker together. The pistons are ross racing pistons. After making a few calls they said that three off the pistons are different for clearance. I found the three pistons that are slightly different and installed them in the number 8 cylinder to check and see if they would clear the reluctor. All of the pistons that i have tried are still hitting the reluctor wheel. Its a manley 4.00" crank and manley h beam 6.125" rods. Anybody run into a similar issue?
Thanks,
Pete
Old 08-23-2013, 11:05 PM
82cetuner's Avatar
never heard of this issue but there should not be 3 pistons that need to be noched, can you take a picture of the notches? maybe they were not machined right or the pistons were not for a stroked engine
Old 08-24-2013, 08:26 PM
S10xGN's Avatar
Usually, it's just #8 that needs a clearance notch...
Old 08-26-2013, 12:23 AM
SShep71's Avatar
What you do to one piston you should do to the other pistons to keep the correct balance.
Old 08-26-2013, 05:52 PM
S10xGN's Avatar
Pretty sure piston mfg'ers have taken this into account when they built them...
Quick Reply: 404 ls stroker pistons wont clear reluctor wheel
