67 camaro 6.0/4l60e
67 camaro 6.0/4l60e
I am getting ready to put a ls in my 67 camaro. First off i have 2008 6.0 out of a hybrid tahoe with ls3 heads. I will be using psi harness which uses E38 ECM, T42 TCM. In the side notes it says harness internal in trans needs to be 15-17 pin connections with iss. Can you swap out harness into older 4l60e? Also what are best headers/motor mounts for 67 camaro ls swap. Pictures would be good if you have them. I was looking at hooker super comps and dougs also.
