all you BW guys, what would you put on a 4.8?
Old 08-24-2013, 10:28 PM
merim123's Avatar
Default all you BW guys, what would you put on a 4.8?
fbody, stock 4.8, th400, ls6 intake/cam, pac springs, 3000 stall, mainly street cruiser, 3.42 gears for now, got a t6 hotside, so needs to be on a t6 frame, front mount, thoughts?
Old 08-24-2013, 10:39 PM
Quickfrc's Avatar
s472 t4
Old 08-24-2013, 11:14 PM
slowlsx's Avatar
Originally Posted by Quickfrc
s472 t4
He specifically said t6 turbo, going t4 would cause another $200
With that said I woukd run tye same s472/83 which is $650 althought if you want room to grow go with the s475/83 which is the same price! Spool difference wont be much different and if you ever want a quicker spool and more power you can always run a more turbo oriented camshaft.
Old 08-24-2013, 11:30 PM
robsquikz28's Avatar
s475.
Old 08-25-2013, 01:30 AM
Quickfrc's Avatar
Whoops. Didn't read that far. T6 is too big for that motor IMO. I have a 6.0 and wish I went T4.
Old 08-25-2013, 10:18 AM
Blackpanther99's Avatar
Originally Posted by robsquikz28
s475.
x2^ People have had good results with these T6 turbos on 4.8s at low boost.
Old 08-25-2013, 11:39 AM
Preston99WS6's Avatar
S475 with a 83mm turbine and 1.10 A/R housing, if its a street car/truck. Foose04' s RCSB made over 900 rwhp with one last year with a 4.8, TU1 cam, truck manifold and E85 and it was very responsive.
Maybe DrTurbo will chime in. The 96mm turbine is a little on the big side for a street driven 4.8 but would work good at the track with a 2 step though.
Not sure but I think the 650 dollar unit has the 96mm turbine, it cost a little extra to get the different turbine and smaller A/R housing's.
Old 08-25-2013, 11:49 AM
slowlsx's Avatar
Negative, same price... just bought one.
Old 08-25-2013, 05:15 PM
Who sells them for 650 with that turbine?
Old 08-25-2013, 05:40 PM
slowlsx's Avatar
http://forcedinductions.com/productsborgwarner.htm
Got mine from HS. There are two listed, one is 649 the ither is 699 same specs.
Old 08-25-2013, 10:20 PM
merim123's Avatar
so I'm hearing the .83 turbine and the 1.10 a/r to get started?
Old 08-26-2013, 12:26 AM
9 Second Truck Club
stock48's Avatar
S475/83, 1.0 T4 with port match would be my pick but there are .90-1.0 T6 housings out now as well.
Quick Reply: all you BW guys, what would you put on a 4.8?
