Build Input
Old 08-25-2013, 09:24 PM
98legendws6's Avatar
Default Build Input
I am trying to iron out the last things before my engine goes back in my 98 Trans AM. Have a built LS3, 10:1 compression, CNCd LS3 heads, 228/234 588/598 cam, LS3 intake, NW 90, D1SC w/ SDCE bracket, 7.25 crank pulley, have both a 4.0 and 3.4 blower pulleys, open exhaust....
Im trying to figure out what pulley to run and not sure what boost each one should make. From that I will figure out what map sensor I need. Although as far as I know the 98 computer wont support anything higher than a 2 bar???
So if im correct about 2 bar that limits the capability to 14.7 psi. So can anyone tell me what boost they estimate this setup will make and if im correct about the 2 bar sensor limit to the 98 ecu.
Thanks
Matt
Old 08-29-2013, 07:59 PM
Any input appreciated
Quick Reply: Build Input
