Fbody Clutch air bubbles video inside!!!!
assumeing you are not sucking the fluid out of the MC than yes those bubbles are normal on a bleed. if you are sucking fluid out also, try it with 5-7 psi
I did not have success with the MV and wound up bench bleeding MC then connecting to slave that also was bench bleed then pump slave from bottom until bubbles stop coming up is resovoir
