99 camaro gaugle cluster bezel, T/A aftermarket ant. LT Radiator support, t-top trim
Category: Accessories
Price: $0
Location (State): UT
Item Condition: Brand New
LS Engine?: Fits LS Engine
Aftermarket Trans Am retracting antenna. This worked fine before removal. It was hardwired to the car. I cut on the car side of the connection so you would know where to connect this at on your harness. $25.00 shipped OBO
93-97 Lt1 Radiator support. This was cracked at one point and repaired with some jbweld or glue of some sort. You may or may not see the crack in the pictures. Either way, it still works fine. $25.00 shipped on this.
T-top trim plastic. Good condition, not broken through like so many do where the screw mounts them up. $20.00 shipped. These are from a 99 Trans am, so they are the graphite Gray.
