Remove Plate Inside Valve Covers?
I fabed my own spacers but a friend just stacked up washers and glued them together. After you install the bolts and factory spacers the washers or new spacers wont go anywhere as they are cpatured by the bolt.
Hot Rods, money pit!!
Chad
If you do the LS6 valley for the PCV system I would think it would be fine to remove the baffle in the valve covers. I think the LS6 valley should be done on every car though since it seems to decrease oil consumption.
